Pulley/belt squeak
310Raptor
Los Angeles
From what I have gathered, Ford doesn’t think it’s an issue until they start receiving other reports. As much as it sucks bringing it in, seems like a necessary step for us to get fixed. Honestly think they could diagnose very easily if they took the belt off and started the truck to see if sound still present. No way it should take weeks to diagnose. I also called ford customer service and started a case so they can hopefully help fast track if dealer drags their feet.
Jeddler
Midland, TX
Make ready guy at the dealership also scratched the hell out of my driver rear window by scraping off the stickers with a messed up razor blade. They said that they will replace the window or pay for a detailer to attempt to polish them out. FML
Jeddler
Midland, TX
Just texted my salesman to let him know about the noise. He has been the go between to set up everything with the Service Department (Loaner vehicle, scheduling, etc.) Told him the 2025 R order that he already offered to me is looking very appealing with all of the unrelated issues on top of this noise.
310Raptor
Los Angeles
Update. Shop foreman had a listen. He heard the noise. He thinks it’s normal. Basically more of the same, deferring it to until Ford reports it’s an issue. I have an open case with Ford, they have offered to engage the dealer when I bring it back and help figure it out. I don’t really have the time right now to go back and forth to dealer.
I think all with this noise should call ford customer service and report a squeaky pulley/belt noise at cold start, takes less time than dealer and will help them build the case for future squeakers.
310Raptor
Los Angeles
Hi guys, I’ve done a pretty deep internet dive on this. It seems like the same issue the coyotes were having that they issued a TSB on. Apparently this issue has affected other engines after the TSB as well. Always passenger side, sounds like belt chirp, goes away when warm. Fix was cam phasers, timing chain, or in one case just vct solenoids. As the 5.2l predator is a coyote variant, it could be the same issue showing with the R. Im no mechanic but the similarities are pretty obvious. Also worth noting, the 5.0 f150s had a similar issue with the fix being a timing chain tensioner.
I’m hoping it’s the latter.
I’m gonna have a mechanic I trust listen to it with a stethoscope to determine where it’s coming from, my ear points towards the passenger side valve cover area and not a pulley.
BoostCreep
BoostCreep
SoCal
Interesting thread I found with Coyote owners experiencing same noise. Happened only on cold start, few mins in. Noise is identical to mine. Fix listed in thread. Hope that’s not the issue as the repairs seem extensive.
This is probably what it is unfortunately because when I listened to mine with a stethoscope it wasn’t coming from the pulleys or idlers, it was coming from where the oil fill cap is, right next to the phasers.
@FordTechOne ever heard of this issue on Coyotes, Voodoos, or Predators?
310Raptor
Los Angeles
Quick update. Had my mechanic (runs Porsche shop, been a mechanic for 40 years) give it a listen with a stethoscope. He is nearly positive it’s coming from idle tensioner pulley. Going back in a few days to run without belt on.
BoostCreep
BoostCreep
SoCal
That should be pretty easy if that’s what it is. Will you leave it over night? Mine only does it on a true cold start and not for long.
310Raptor
Los Angeles
@BoostCreep Today I left it there early am with hood up, came back 6 hrs later to start it for him to listen. Prob do the same. It’s been cold here in socal last few days and the noise presented after doing that
