Frank N
So wait two batteries…. Can you jumpstart yourself?
2kw only for raptor as a $995 option in 2022. No hybrid raptors yet.If I understand it correctly on the 2021 Raptor the 2.4 kw generator is standard and the 7.2 kw is an upgrade option. Others will know better than me and maybe someone can add some wisdom here.
Both alternators are clutched, so they are be disengaged from the belt drive when not needed. The secondary alternator stays in a standby mode when demand is low, so there will be little to no additional drag. When the primary generator is at maximum output, the secondary generator is engaged. The maximum system output when stationary is 2kW; when driving the maximum is reduced to 1.5kW.Hi
I finally found a dealer to order a 37 pkg. I was interested in the Pro Power OnBoard 2kw option. According to specs online, this option adds an additional alternator(generator) and battery. Will dual alternators reduce engine horsepower and torque or is it negligible?
Thanks for info. I'm going to get it. What's 1K when spending 80K.Both alternators are clutched, so they are be disengaged from the belt drive when not needed. The secondary alternator stays in a standby mode when demand is low, so there will be little to no additional drag. When the primary generator is at maximum output, the secondary generator is engaged. The maximum system output when stationary is 2kW; when driving the maximum is reduced to 1.5kW.
For the price of the system, I can't see not opting for it. The use cases are endless.
