Pre-Run for Creatures of the Night, Brawley - Plaster City - Carrizzo Gorge
E63
Poway, CA.
Was invited to help Matt do the pre-run of this portion of a future Raptor Expedition Run.
We met in Brawley and left at 9:00am, it was already above 90 degrees and humid. Our trail takes us past several farms and aqueducts and turns into open desert. There was ample evidence of the heavy rains and flash floods. (I noticed Earthquake damage on trip out on I8 with rock slides and fallen 2 story high Hay bales too) Always different and changing, our deserts… Early part of the run, there was a lot of standing water around, we followed a previously run charted path that went on top of the levies, for lack of a better description. I am following quite a ways back due to dust and get the call to be careful, he’s stuck in mud.
Time to break out the new recovery gear, first we tried pulling him out backwards
Made things worse as we hit a wall of mud. Now strap and shackle is buried.
Here is short video:
I wanted to try the Wythe Hand Winch, thought was to use my truck as anchor
That didn’t work, only pulled my truck backwards. Funny thing – we are sweating bucket by now, 114 degrees with high humidity – not thinking completely sharp, anyway we go thru the motions to relieve tension a few clicks at a time, five minutes of this and Alain (Matt’s Navigator) say’s “Why don’t you just back your truck up a bit?” Doh!:doh:
The only shovel we had was my little POS, which was fairly ineffective:i_redface:
So the next step was to try and get my truck around and pull him from the other way. Two problems, one getting our strap off the back and getting around all that water without getting stuck ourselves.
Matt stays in cell phone contact with Connor and Outlaw, keeping them apprised of our situation (this little fact will make more sense when we get to the end of this story.) So Matt jumps in and we do some off trail blazing and are able to position truck to pull from front.
My Son Ian, braved the leeches to hook up my sling to Matt’s LCA. I am not kidding either they were everywhere, little green bastards. We use an under-rated strap to pull him about 3 feet or so before it broke. Then Ian braved the nasty water again, up to his ass, to retrieve the good strap and shackle.
Success – Matt’s Truck is fine, time to clean up and be on our way
---------- Post added at 05:20 PM ---------- Previous post was at 05:17 PM ----------
2 hours later – we are all soaking wet with sweat, time to get the thousand flies out of our trucks and then to enjoy the A/C and open desert. :pepper: :pepper: :pepper:
We had a blast, made good time, saw some interesting stuff on our way past the state Prison. Stopped for some cold beer by the first shade tree we found, none of the bottles broke, :smileup:but many of the caps could not contain its cargo :smiledown: Enough survived though :smiley_thumbs_up:
We made our way for the next couple hours on some really fun trails thru Ocatillo and into Carrizzo all the way to the base of the mountains. SDGE is working on a new wind farm and had graded some dirt freeways that were a blast to zoom on. :pepper:
Then it was time for some high speed trail blazing with some wild blind turns with thick vegetation on all sides. It was beautiful stuff, by far the most fun.
:pepper::pepper::pepper: We tried to continue the trail across S-2 down into Canyon Sim Nombre but the trail was too overgrown and unused, I convinced Matt to take the marked trail.
here is the overlook:
This piece has some tricky passages best done with outside help to guide you. I was careful as I had gashed a sidewall in this very spot on a previous journey going the other way. Trail leads down to some 100 foot cliffs where we stopped for lunch before the assault into the Carrizzo Wash.
This area is heavily overgrown with water there year round.
We decide to do a little landscape maintenance, my crappy shovel had a crappy saw inside and we hacked our way thru this enough to break it so we could drive over it.
The wash was completely different from when Noah and I had gone the other way about 6 weeks ago, the entire area was filled with this stuff:
It was like drive on field of glass, stuff shatters easily with a satisfying sound, flying everywhere. We blazed thru it 60 MPH, taking one to two foot jumps in the undulations of the wash. Lot of fun.
We came out at the tracks that lead to the Plaster City Factory, no doubt startling the Border Patrol guy seen at the back. We drove right by him and then backed in for a photo
Real Mud graphic
Minor trail scratches
E63
E63
Poway, CA.
We continue on our way, following the train tracks. The main road is washed out in several places.
At one point Matt has trouble climbing out of a rut that pushed his truck close to the high side wall. He stopped and waiting for help before proceeding. We tried filling the rut with large boulders, but the right tires were both in it and as he tried to climb the right rear fender nestled up against the sand ledge.
Once again the crappy shovel came out and we carved a 6” or so gap to allow for more room, also did extensive work to provide a better path out.
Yup, wiz was there!
With side walled carved back and trenches filled, Matt escapes unharmed – Here is short video of the escape:
Desert is filled with this kind of stuff, here is an intact oyster shell, This whole area used to be part of the gulf of Baja.
When we were driving out, Thermo got as high as 124 degrees, Matt’s read 129 at same point!
All in all a great Raptor day, Had one last beer with Matt and Alan and headed home.
---------- Post added at 05:25 PM ---------- Previous post was at 05:23 PM ----------
Saturday morning, I get a text from Matt. Connor is missing for 18 hours (he and Wayne were in the Outlaw Raptor doing another section of the pre-run), full search is in effect, Sherrif, helicopter etc. As these things go info is always on the light side, what we thought was that he had a “Spot” (emergency transponder” and a Sat phone. The crew from outlaw had his specific course too. So based upon the time missing, suspected he would be in the mountains. Based upon these facts, I am thinking the worst.
I am on stand by ready to head out in the search. Matt is at Outlaw coordinating the search. Some nerve wracking hours go by. At 6:00 we learned he was ok, had gotten stuck, forgot Spot at office and Sat Phone didn’t work, CC expired!
They walked 15 miles in that heat to get help. I am sure there is more to this story, very glad it all worked out ok.
---------- Post added at 05:26 PM ---------- Previous post was at 05:25 PM ----------
So after reviewing the trip and its many lessons, I ordered a 30’ Snatch Strap, 2 more shackles, a 10” Sling Strap and a Hi-Lift “All in One” bag today to complete my recovery gear. Well almost, still will add a landscaping Saw and heavy duty gloves.
here is some pics of the "All in One"
This four-in-one off-road recovery tool (including shovel, axe, pickaxe and sledgehammer) has a two-piece telescoping handle that's held together with strong, yet easy to operate, quick release Tab-Lok pins. You can shorten the handle for working in tight spaces by simply removing one of the tubes. The tool heads have been CNC's to fit snuggle into the tubes. They are also held in place with TAB-LOK pins.
WHY IT MATTERS /// It's essential to have recovery equipment that's well built and easy to carry. This device features cast steel construction and has been milled with strict tolerances it terms of fit; i.e., it's strong and the different implements fit together perfectly.
WHERE TO BUY IT /// Hi-Lift Jack Company - Highest quality equipment at a reasonable price ($159.99) Or Amazon for $118
Read more: Hi-Lift Handle-All - Popular Mechanics
And it all fits in this tiny bag
Netix
Banned
Ontario, Canada
Event full huh. Been stuck in situations like these it never in a dessert cant imagine that. Although I did get my quad stuck 85km from a nearest road in the bush here 150km south of the article circle when I went moose hunting. My atv with tracks and my buddies Argo. We both got stuck really bad in in a frozen swamp. Ditched the rides and packed as much survival gear back with us. Spent 4 days trying to backtrack until we hit a power line trail, followed it down another 10-15km and reach a small township of 150 people. When you are stuck in the middle of nowhere it sucks!! In 125f heat is dangerous but so is -35c :/
Squatting Dog
Kansas City, MO
I love mine.. The bag is heavy, but worth the weight when you need it.
I would suggest getting a big bubba rope.. I have used it several times and it sure beats standard snatch straps. I use big bubba first, and two snatch straps as back ups.
-Greg
Aaron
Meme Corps Commandant
WA
Wow, crazy ending to that story. Getting stuck in the desert can go very wrong very quickly. If you've got water and a vehicle with working AC, leaving it is a VERY bad idea.
I'm not monday morning quarterbacking the situation, but saying it in case someone else reads this. Especially in the case of an air search, a vehicle is a much easier thing to spot from the air than a person walking. Plus at night you can turn on lights and make yourself a beacon.
If you have to walk, it's important to leave a note stating which direction you were going and what your intended destination is or even just an arrow indicating direction of travel. The odds of survival tip against you in a very serious way when you leave your vehicle.
Sorry...I'll stop now. I'm glad everyone made it back safe and that everything worked out. It sounds like you guys had a great time even with the minor scare!
treypal
Lord of the Raptors
Riviera TX
Looks like fun. Hit me up if you are interested in a bubba rope. I sell them.
My spot stays zip tied to my truck. I carry no less than a dozen lithium batteries for it. My help contacts are all people I trust (family) and they have information sheets with who to contact and what to do depending on what part of the world i am in when I hit the help button.
E63
E63
Poway, CA.
It was only over a 120 for this one small section, really weird. rest of the day it stayed about 114
That is amazing survival story - Man vs. Wild stuff. I did a little survival training with Boy Scouts, never had to use luckily!
-Greg
I saw that, but never heard much about them, ended up getting an ARB 30' from Amazon. So I will have 2 each 30 foot straps, one snatch and the others static, plus 3' and 10' slings, 4 shackles, the Wyeth with 35' Blue Steel, plus will order the ground stakes, - I found some on Amazon for under $10 delivered. 11IWHaFyG6L._SL500_AA300_.jpg
Thanks for posting these sound safety practices. I'm sure he is embarrassed by the episode as he knows better. But mistakes and accidents happen, and in that heat, its difficult to think 100% clearly. Lord knows we made some strange calls as we worked toward finding the right solution to our own challenges.
I am so very glad this didn't turn out to be the kind of a story you read about in the newspapers.
Looks like fun. Hit me up if you are interested in a bubba rope. I sell them. :doh:
In an Eddie Murphy excited voice "You r a Raptor, livin on the edge!"
I have done these single vehicle journeys many times, exhilarating yes, nerve wracking - you bet. It is just so much more fun and safe to go out in pairs or more. Especially in the heat of summer where all the other off roaders are hibernating. During nice weather, the local desert(s) is crawling with folks, not likely you will be far from help if needed.
Aaron
WA
E63, I did leave out one important detail about deciding to leave your vehicle that I wanted to add. We were stressed on this point over and over in the military:
Only leave your current site (vehicle) If you are forced to do so or if you are certain you can acquire one of your basic needs for survival by doing so (Food,water,shelter). If you know you can improve your situation by meeting one of those needs, then leaving is a worthwhile proposition.
Netix: Dude believe it or not, it's actually almost easier to survive in the winter given the right combination of gear. Basically it amounts to bringing stuff to start a fire, and then having a shovel to dig yourself a snow cave (into the side of a big drift is best, then you just dig in, up and in a bit more and you build your fire out at the entrance. The heat will come inside and keep you nice and warm in there. Then it's all about having food with you like powerbars and such and making some kind of signal to help people find you. Staying dry is obviously also key.
Sorry, I posted a lot more than I had planned on...
Netix
Banned
Ontario, Canada
Bear grylls over here eh . But I agree I wouldn't survive in the dessert
Blind1
Central Alabama
Wow, Gordon that's one of helluva pre-run. I'm glad everyone is alright, and it looks like we all are learning a lot from this thread. Thanks for posting.
