Power Steering Blowout & Failure!
Chris@FreedomMotorsports
FRF Gofur
Woodlawn, Virginia
Update:
That being said, per Howe, the plan is to have a complete kit that is a workable upgrade for the Raptor. While the reservoir and cooler combo would indeed be an upgrade over stock, to make it work with the stock power steering pump, you (the end user) would have to do some fabrication to make that smaller package work as they are going with AN fittings on the lines, etc. To make a smaller kit to work with the stock pump would mean more fabrication and R&D that could drive the price of the kits up even more. They do not have plans to create or offer a smaller kit for just the reservoir and cooler.
The advantage to the full system is that when upgrading everything up to and including the pump, you are providing higher, more consistent overall pressure in the PS system. You see, when offroading, because of the design of the stock system, every time you hit a bump, the rack demands different pressures from the stock pump. So the system/pump is continuously demanding higher PSI to maintain proper control. Even with stock size tires, but especially when larger tires are added to the mix, this constant fluctuation in system pressure causes the fluid in the system to heat up to the point that the fluid begins to break down and lose overall lubricity. You also wind up with "cavitation" (air in the system) due to the design of the factory reservoir baffling. With other aftermarket reservoirs on the market, the reason they have a positive affect on the longevity of the system is mainly due to the design of the reservoir baffling to help avoid that cavitation or air intrusion in the system. Multiply the air intrusion with the over heated fluid in stressful offroad situations and you have a recipe for both burned up pumps and steering racks both. ESPECIALLY in rocky environments like Raush Creek. An example being the last Havoc in the hills event when racks and pumps were dropping like flies in trucks that were for the most part stock.
As for the mounting of the reservoir/cooler combo. Mounting in the stock location as designed is not an option due to the overall height of the combo. Also, if you have aftermarket light bars or a super charger cooler behind the grill, you will indeed have to get creative with fabricating a new mount to make them work. While the rest of the kit, like e power steering pump, is bolt on replacement due to the new pump mount that Howe has designed, some customers may need to get creative with the mounting of the res and cooler combo due to their other specific mods. This package is designed for use on generally stock trucks for the most part.
FRF Gofur
Woodlawn, Virginia
Ok, another update. The timing is still out a bit. Howe is manufacturing the AN fittings in house in bulk. Once they are done, they will be sending the lines (specifically the lines leading to the steering rack itself) and the AN fittings to all be welded together at the same time. That way, with how they are going about making the kits happen, they will be ready to keep up with demand once they begin shipping.
THAT being said, I have been authorized to offer a group buy. If we can get just THREE or more orders, I can offer an additional 15% OFF the price! That brings the sale price of the complete kit down from $1245 + $30 shipped to $1083.75 SHIPPED!!! So who's in?
FRF Gofur
Woodlawn, Virginia
We have invoiced enough of the kits now to meet the threshold for the discount. So it is happening for those that want them at a discount. Just send me a private message with your email address and I will get a Paypal email invoice sent to complete your preorder!
RLTW
TX
Chris do you have me on this or no
RLTW
TX
Well you know the answer to that
FRF Gofur
Woodlawn, Virginia
@Chris@FreedomMotorsports
How much time will it take for Howe to get these kits ready to ship ?
May be interested...
The latest update as of yesterday is that the AN fittings are being machined this week, then those and the lines will be sent to welding to finish those up next week and the kits should be packaged and ready to ship out by the end of the following week.
