Power inverter question
akbjr
Hello,
Just got a 2023 gen 3 and have a question regarding the inverter and outlets that are available in the bed and the cab. Are these to be used only when the engine is running and if they are used when the engine is off I am assuming they can drain the battery? Is there a meter that shows the battery health to gauge how much power has been used? I DO NOT have the 2kw PRO power on board, just the standard plugs and the inverter that i see under he right potion of the rear seat.
thanks
grussell
Lawrenceville, GA
Hello,
thanks
I also found this to be off putting. is there a way to keep the power supply on with engine off perhaps through forscan? btw I do have the 2kw in the bed.
FordTechOne
Detroit
2kw is 166 amps. That would drain your battery almost instantly, that’s why the truck needs to be running.
Ytown
Yuma, AZ
You can use forscan and enable it to stay on when truck is off. Same with in the interior but I believe those time out after 120 minutes.
95,320
58,843
brucebarson
Latest posts
