Possible overfilled transmission
Justbob
MD
Odd question but I did a transmission fluid change (just pan volume) about 1000 miles ago. Long story but I ended but “tracking” fluid into my truck from my shoes/spilt fluid and have been smelling it ever since. Fast forward and washed the interior of the truck (weather techs) and seat last weekend. And I still smell the trans fluid, but not when I get in the truck, only after driving it longer distances (more than grocery store). Now I am convinced I smell the sent of “burnt oil/trans fluid” when I step out of the truck when I stop after those longer trips. The truck drives and shifts fine. What I am concerned with is when finalizing the fluid level, I was in a rush and ran the truck on the lift for 15 minutes , jumped in and checked the “temp gauge”….i am thinking I looked at the coolant gage and not the transmission gage when I finalized the fluid level. Assuming I am right (or really wrong) and the fluid was still “cold” but set to the hash marks on the transmission dipstick, what are the consequences of running “too much” transmission fluid ?
Canuck714
San Antonio TX
If the trans was "cold" the bypass to the cooler was still closed.
If you measured the level and trans was still cold, you would actually be a little low once the thermostat opened and allows trans fluid to run through the lines and up to the cooler.
I don't think you are in a "over filled" situation.
As for the smell.... I am betting that there was trans fluid spilled on the exhaust crossover pipe and has not completely burnt off yet.
