Pop sound from front left when using 4a
REX111
REX111
Sussex
I found out today that the noise will happen multiple times if driving forward then reversing. I’ll be taking it back later this week.
AEC
Las Vegas, NV
Did you ever find out what the issue was? I am having the same issue, on my way to the dealer for the 4th time.
FordTechOne
Detroit
Is the truck at factory ride height/stock suspension? If so, the first thing I would check is the torque on the front axle nuts. Next would be inspection of the IWEs and axles.
REX111
REX111
Sussex
Dropped it off this morning. Went for a ride with a technician so he could hear the noise. Third turn and to pop noise happened. The tech said that not normal. Still don’t have an answer yet.
REX111
REX111
Sussex
Dropped truck off to have axle installed. Tech test drove it and the noise remains. I'm reaching out to ford to see what can be done.
CoronaRaptor
CANADA
Your dealer are clueless fuc ks. It's not a complicated vehicle to work on. Must be chevy techs working there. Hope Ford can send a field tech out to diagnos for you, so sad.
