Poor Design
swoop1156
USA
No shit. I'll be cleaning this while xBX is busting his ass with the perch adjustment!
IRONMAN
IRONMAN
Well-Known Member
MICHIGAN
I'd say that surgical tube trick is the way to go for that...
How would you use the surgical tube for this?
The water is coming from under the truck and seeps past the yellow washers or whatever they're called.
JP7
Likes Canadian Mudbaths
Calgary, Alberta
Hydrostatic pressure is whats happening. When the washers are wet, they hold moisture between them and the body. Lube the **** outta them too!
IRONMAN
IRONMAN
Well-Known Member
MICHIGAN
This I will definitely do. Vaseline away...
JP7
Calgary, Alberta
Carefull - if they are rubber, the petroleum based Vaseline may cause them to embrittle over the years. a Butyl based product may work longer, unless you plan to dump the truck in 5 years or so.
IRONMAN
IRONMAN
Well-Known Member
MICHIGAN
So what product then would be the best for this. It might depend on what exactly those yellow washers are made of.
Hockster
My 45ft Bluewater Party
Winchester, Va
Ah i missed that hole there... dam... why the **** did they do that? I need to look at that on mine and see... No way should that slot be through the truck floor.... that is a shit design for sure...
JP7
Calgary, Alberta
Lol - mine are frozen so I can't tell what they are!
If it feels like they are rubber (soft, flexible) then grab a tube of gutter sealant from **** Depot. That stuff is almost pure butyl, and won't harm rubber. It never really cures, so it will stay soft and flexible for years.
If they are plastic, silicone is a better choice as it bonds well to both surfaces. It will cure, but as long as it has no sun exposure - it can last 20 years.
With either sealant - prep all surfaces with rubbing alcohol first as a primer/cleaner. That shit evaporates quick, and doesn't leave an oily residue. I buy the alcohol pads from the drugstore (in the diabetes section) as they are great for wiping things down then you can jsut throw away the pad.
IRONMAN
IRONMAN
Well-Known Member
MICHIGAN
Yes they were flexable / soft.
I don't understand why in the world ford eng.'s wouldn't design a better way of holding those down with out cutting through the body.
Just stupid.
