Pinch weld - front fenders
j_chil
You don't trim with fenders, not the fronts anyways. Top perch is bad for 4wd and it's not needed with the fenders anyways.
In the front i do have to cut the bumper and the front wheel hits the body on the back at 3/4 turn. I will get pictures up later but im looking for someone who has done this before.
khcdave
South Brunswick NJ
here ya go. this is how I do them. Its is needed especially if you are running inner fender liners. They wont fit otherwise. I use the glassworks ones
BRAPPPP
San Luis Obispo, Ca
No this is a suspension shop that just cuts and beats the metal away. A professional body shop would cut the welds hammer it flat re weld it and paint it.
ntm
Alberta, Canada
There's several pieces of sheet metal in that pinch weld, not just two pieces.
It would be less structurally sound to cut out the pinch seam and attempt to edge weld a joint where four pieces of sheet metal meet. Especially with no access to back weld.
What Dave did there is more or less exactly what most body shops do. They don't make quite as many relief cuts, and use a body caulking to make sure the seams stay waterproof.
BRAPPPP
San Luis Obispo, Ca
Does anyone have a link or a thread to a full detailed write up on how this is done? I would like to take it to a pro body shop so they have an idea of what needs to be done
ntm
Alberta, Canada
It's pretty straight forward. If a bunch of garage monkeys can do it, a "pro" body shop will make short work of it.
Just tell them you want the firewall seam clearanced for your 37's, they'll do the rest.
