Pieced together a carbon fiber interior package
K223
Florida
******** this forum! Thanks- I just bought one lol
that’s a good price
Damn 158 bucks for the shifter, that’s cheap. It says 2020 but shows the DM button in the pic for 17-18’s. Maybe just the wrong graphic? I’d buy one if I knew it didn’t have the button. I already have a Sync cubby storage door on hand.
metaphysician
metaphysician
DE
It's a really good match to OEM. I have extra CF door inserts for the rear SCREW doors that I didn't need since I have a SCAB. I'll get a picture of those pieces next to the OEM Sync media door to compare.
Here's a side by side. I'd say it's a perfect match in weave, color, and gloss. Even if there was a little variation, none of the pieces are right next to each other.
metaphysician
metaphysician
DE
Did you install the media door yourself? How bad was it?
Yes, I did all the work. You have to remove the center console and cupholder/shifter insert. I did it the same time as the shifter. The Sync door was held in by 2 torx screws at the front (near the shifter).
The shifter and media door took probably 30 mins. Make sure to pay attention to the 2 set screws that hold the shifter on...they have like 3 threads and are tiny.
Here's the video I referenced:
Badgertits
Ma
lotta times pics don’t match the item referenced, I don’t care even if it does the switch (although that ain’t the switch you’re talking bout- the 17-18 trucks have a +\- switch for shifting) it’ll still work
metaphysician
metaphysician
DE
The part # for the CF shifter WITHOUT tow button (2019-2020) is KL3Z-7213-HB. The previous part # WITH tow button is HL3Z-7213-HB.
mattl600
Los Angeles
I just ordered the carbon dash kit. I already have the factory carbon package but like the drivers side small additions.
anyone want to buy the glove box upper trim from me?
K223
Florida
I may be interested. This is a direct replacement or stick on overlay? This was the aftermarket piece correct?
metaphysician
metaphysician
DE
If he bought the dashboard kit I linked, it's an overlay. You could remove the OEM trim, but there isn't much for the the CF overlay to evenly stick to (no clips, just adhesive). It's a perfect fit on top of the OEM trim and even has little notches on the sides to fit around the other parts of the glovebox/dash.
