CineSLR
Roaming Shutterbug
The projectors don't put out much light as halogens. I've been into Off Road Lighting for many years and what it comes down to for the best lighting is using the best reflector.
Sorry Mic,
Couldn't disagree with you more here. The reason for the lower light output is not because of the design, projectors are far superior in handling/controlling light than a reflector ever will be. Its actually because of the ****** projectors Recon/Chinese company that actually produces them, decided to use in those particular housings. Off road lighting and on-road low-beams are two completely different animals. Have you seen Ducati's retrofit he did on his Recons? If your not happy with the output, I would highly suggest checking it out and getting a decent projector in there. Not only will you gain the option of adding a bi-xenon setup, you will finally be able to utilize the full potential of the HIDs (if your running them). Believe me, it will be a night and day difference and worth every penny.
aaaaaaand I'm sure I'm not the first to say that your wife is a TROOPER!
