Pic of the radio. Nothing too exciting, but I did use a magnetic mic mount which is pretty nifty:
And after a little over 3 and half months, the Deavers finally showed up. And like a crazy person, I tackled the install solo. Do not recommend. Those things are heavy and awkward. Got er done though, and very happy with ride so far:
I referenced this thread which was helpful, but few notes:
- I didn't need to order new front bolts (but already had) as the Deavers come with brand new cut-down bolts
- You also don't need to transfer over the upper u-bolt plate as the Deavers come with them already
Discovered a leaky axle seal while I was under there, so that sucks. Especially since I just did the diff fluid last year and that oil is super expensive. While ordering expensive fluid, I figured I'd go ahead and get some more Mercon LV and a transmission filter, even though I recently had the tranny fluid flushed as well.
Low speed bumping has not gone away completely with the new leaves, but has dissipated somewhat.
