PCM
REBELx504
New Orleans
Is this after you tried the reset?
yep...vehicle starts fine...runs awesome for about 2 minutes, after warm up vehicle rpm drops below 800 and engine stalls...if you hold foot on petal and hold idle above 800 she runs GREAT, even driven all around town!!!, as soon as you let off the petal she stalls out with no codes or MIL??????
Hockster
My 45ft Bluewater Party
Winchester, Va
No tune? All 100% stock? Check the intake air for a leak. Might be a loose clamp or a tube that has moved allowing un-metered air past the MAF. Could be the TPS (throttle position switch) Sounding like it cant fine idle position.
REBELx504
New Orleans
smoke test found one small crack in intake , but was very very small and repair made no change...I am leaning to either accelerator pedal or PCM
