PCM
Huck
Chicago Sw Burbs
Search is failing me. What happened to that post on how to reset the PCM
RaptorWifey
FRF Lady
Oak Island NC
I don't know what PCM is, but I do know that the search function doesn't like three letter words...like lug nut:perkinswhatever:
Huck
Huck
Chicago Sw Burbs
It's the vehicle control module, handles shift points fuel trims etc, someone posted the process but everything in the forum is 3 letter abbreviations and impossible to find anything
Kanakry
Great Lakes Region
Powertrain control module. Made by Continental Automotive Systems.
Sent from my ADR6400L using Tapatalk 2
Huck
Huck
Chicago Sw Burbs
Ok Jason what's the process to reset it? Someone had some long process of being in gear for a whole, neutral, etc
Hockster
My 45ft Bluewater Party
Winchester, Va
Resetting The Keep Alive Memory (KAM)
Description
Resetting the KAM returns the powertrain control module (PCM) memory to its default setting. Adaptive learning contents such as adaptive airflow, idle speed, refueling event, and fuel trim are included. Clearing the continuous diagnostic trouble codes (DTCs) and resetting the emission monitors information in the PCM, is part of a KAM reset. Refer to Clear The Continuous Diagnostic Trouble Codes (DTCs) And Reset The Emission Monitors Information In The Powertrain Control Module (PCM) in this section. Both can be useful in post-repair testing.
After the KAM has been reset, the vehicle may exhibit certain driveability concerns. It is necessary to allow the engine to idle at normal operating temperature with the A/C off for 2 minutes. Then drive the vehicle to allow the PCM to learn the values for optimum driveability and performance.
This function may not be supported by all scan tools. Refer to the scan tool manufacturer's instruction manual.
If an error message is received or the scan tool does not support this function, disconnecting the battery ground cable for a minimum of 5 minutes may be used as an alternative procedure on some vehicles.
Idle Air Trim
Idle air trim is designed to adjust the idle air control calibration to correct for wear and aging of components. When the engine conditions meet the learning requirement, the strategy monitors the engine and determines the values required for ideal idle calibration. The idle air trim values are stored in a table for reference. This table is used by the PCM as a correction factor when controlling the idle speed. The table is stored in the KAM and retains the learned values even after the engine is shut OFF. A DTC is set if the idle air trim has reached its learning limits.
Whenever an idle air control component is replaced, or a repair affecting idle is carried out, it is recommended the KAM be reset. This is necessary so the idle strategy does not use the previously learned idle air trim values.
To reset the KAM, refer to Section 2, Resetting The Keep Alive Memory (KAM) . It is important to note that erasing DTCs with a scan tool does not reset the idle air trim table.
Once the KAM has been reset, the engine must idle for 15 minutes (actual time varies between strategies) to learn new idle air trim values. Idle quality improves as the strategy adapts. Adaptation occurs in 4 separate modes as shown in the following table.
IDLE AIR TRIM LEARNING MODES
Transmission Range Air Conditioning Mode
NEUTRAL A/C ON
NEUTRAL A/C OFF
DRIVE A/C ON
DRIVE A/C OFF
After the 2 minute KAM reset
What I do is do about 3-5 minutes in each mode and you can disconnect the battery to do this without using a scan tool. Using a scan tool keeps all your setting in the system.
Huck
Huck
Chicago Sw Burbs
So pull the battery and let it set then run in each setting for 2 minutes?
Hockster
Winchester, Va
First step... Get the engine warm, Disconnect battery, reconnect it and allow the engine to idle at normal operating temperature with the A/C off for 2 minutes.
Then the next step is let it idle in the 4 diff modes 3-5 min each.
and finally drive the vehicle to allow the PCM to learn the values for optimum driveability and performance.
REBELx504
New Orleans
Description
Idle Air Trim
NEUTRAL A/C ON
NEUTRAL A/C OFF
DRIVE A/C ON
DRIVE A/C OFF
OK, but what if the vehicle wont idle at all????
Vehicle starts fine...runs fine through warm up (about 2 min) then as RPM's drop below 800, it shuts off???
