PCM misfire 2020
Jeff Boone
Memphis TN
2020 Stopped at store. Got back in check engine light flashing and running like **** unless you punch it. App said PCM detected misfire. Any ideas???
FordTechOne
Detroit
Mods? Check for moisture under the engine cover, if it gets into the spark plug wells it can short the coils.
Bad fuel injector per dealer
My Lincoln had the same issue last year but it was much, much less severe. got the codes, I pulled and left alone, rather than clearing. The car was running fine from visible/audible observation, but internet lore held that you’d better take the vehicle in for service. I called and they sent a loaner out ( Lincoln sends a car to you, rather than you coming to them, scheduled of course). It took the tech some time, and apparently several engagements with engineering to run it to ground - and, they never definitively identified the issue so they swapped out all the injectors and the entire rail assembly.
I think they had it about 8 days or so. They will square this right away and that will be that.
