Bringing this one back to life. Was this the permanent fix for you? I got the code on my truck last Monday, cleared it Monday mid-day and had it back Friday afternoon. Swapped the purge valve yesterday morning, drove a bit and it was off this morning when I started the truck. Just did about a 60 mile drive, filled it all the way up on this drive and right before I got back home it was back on. Re-checked purge valve fittings and re-tightened the two 8’s holding it and also jammed the filler neck about 30 times with a gas can hose. I’ve cleared the code again to see what it does. Interested to see what you have to say! Thanks.So far so good, but not many miles since, about 1000km at most. Did you swap the solenoid at the same time? I will take a look at that hose.
