Hello guys and gals I have a 2020 With 53,000 miles. Only mods are intercooler and goose tuned. Truck is used for normal daily driving. I have yet to make any trips, off-road. The truck was running good until about two weeks ago and I had the wrench icon pop up on the instrument luster. So I stopped and pulled out the scanner and hooked it up and got those codes. This happened through town at about 45 miles an hour. So I cleared the codes and drove on home. When I got there of course I googled some stuff but no clear answers were given. A few days later after work the same codes popped up again. And then one more time today which is about a week later. A lot of things I read is showing the camshaft position sensor needs replaced. I just wanted to get your opinion is this a common issue?
Also, while doing the research, I ran into another thread that showed consumption. I noticed my last oil change I was about 3/4 quart low or maybe a little more. no visible leaks and nothing on the ground. Even when the truck sits there for a few days everything is dry. Any input would be greatly appreciated.
