B E N
Before you dig too far in, make sure you have completed the necessary driving cycles to give the truck a chance to reset the HEGO codes.
This is a 2011 pinout but it should be the same. If I was diagnosing this I think I would pop the connector off and measure resistance in that circuit, if it checks out de-pin the slot at the ECU and measure voltage there. Pin 40, diagram 3 (C1381T).
