GEN 2 P0035
nikhsub1
Los Angeles
So i just started getting this P0035 code. Anyone know what it is and is there a quick fix?
TIA!
*edit* I should mention I do have a turbosmart BOV, been running it for a few months though with no issue, until now.
FordTechOne
Detroit
Most likely related to your BOV. Do you hear it working?
P0035 - Turbocharger/Supercharger Bypass Valve A Control Circuit High
Description: This DTC sets when the PCM detects an open circuit or high voltage in the TCBY circuit.
Possible Causes:
  • Damaged turbocharger bypass (TCBY) valve
  • TCBY circuit open
  • TCBY circuit short to voltage
Diagnostic Aids: Check the harness for intermittent concerns, incorrect connections, routing, alterations and damage due to contact with other components.
This DTC only sets when the valve is commanded open.
digscruze
South Fla
P0035 is caused by the BOV. Make sure the crimping tool used is properly crimped Between the OEM cable to avoid the code.
I had the same issue with the connection. However MPT just removed the code from appearing with their tune. However, they confirmed it’s related to the BOV. I have the TS Supersonic BOV.
nikhsub1
nikhsub1
Los Angeles
OK thx. I have an email into turbosmart. Was working fine for the last 3-4 months, although I haven't been driving that much since covid...
ericburney
Desert is the best medicine
Northern Utah
I got one of the first EM BOV. No issues. 30K miles.
Some EM BOVs had issues with the connector clip...if you keep having this happen, contact turnbosmart and they will ask you to send them a photo of their connector to determine the cause. Good luck
