Overheated the Raptor
CoronaRaptor
CANADA
^^^ @CoronaRaptor , I can't reconcile your experience with my own. What brand of magic do you use?
Well, most importantly is to have the equalizer hitch set up properly, I will say, there should be a course given on how to do this set up properly. I see so many trucks towing trailers and the rear end of the truck is dragging on the ground or the complete opposite, it's too high in the air along with the front of the trailer. The trick is to hook up your trailer on the ball first and not hook up the bars yet, then you jack the trailer up until the truck and trailer are even as possible. This is when you attach the chains using the chain bar for a really snug fit, then when you lower the jack back down (or crank it back up into the column) the trailer and truck stay level, this allows for far greater maneuverability of the truck and trailer without it swaying back and forth. It's hard to do with a uhaul trailer as they don't come with those hitches, so best to keep the heaviest load over the axles of the trailer and not at the rear or the front, that's when big problems happen.
Gary E
Medford, Oregon
I tow this 6,000 pound 1942 WWII carbon arc searchlight with no issues...except for cross-winds in Nebraska.
Just returned yesterday from round trip for a motorcycle show in northern California towing an enclosed trailer with three motorcycles totaling about 3,000 pounds over the highest pass on I-5 (from Canada to Mexico) with no issues. OAT's were not hot though.
The Car Stereo Company
here, on frf
you should mount that light on the front grill........ put everyone to shame with it. be able to see for miles.
mprice1234
SVT Gen 1 Rules
Colorado Springs, CO
What in the heck do you use that WWII search light for? Spotting deer? Frying cats at 100 yards?
Gary E
Medford, Oregon
Event enhancement, ie theatre openings, conventions, state/county fairs, city celebrations, rodeos, night clubs, concerts, etc...or just lighting up the moon.
Blu Bug
Blu Bug
Orangevale
Just got back from my desert excursion. Raptor cleared the Sierras fully loaded (approx. 800 lb under max rated weight.) Running at night with the a/c off and never reving over 3k did the trick. Never got over 1/2 way on the dash temp gauge. First off-road run was a short one and coolant boiled out when I stopped to enjoy the scenery. Long story short, after several trial and error test truck never overheated until I shut it off. Could it be the radiator cap?
CoronaRaptor
CANADA
So when you open the hood when its overflowing, is the overflow tank at the "high" mark or at the "cold" mark still? Make sure that tube on the outlet of the rad going into the overflow tank is clear and not plugged. If the tank isn't cycling fluid then it's most likely the rad cap.
CoronaRaptor
CANADA
You up past Mt Shasta?
