ORW Alignment Special!
San Diego, CA
Hey guys,
I know vehicle maintenance can be boring sometimes but we are about to change that.
I am offering an alignment special that is tailored to Raptor owners. We utilize Hunter Laser 4 Wheel Alignment Racks at our shops to give you the best alignment possible.
The Machines and techs that work them are the best in the business. The reflectors used for the alignment grab onto the outside of the tire to eliminate the fear of scuffing your SVT or aftermarket wheels.
We utilize SPC Alignment Cams to eliminate one of the few Raptor OEM weaknesses. The Lower Control Arm alignment eccentrics are prone to shifting when the tire hits an obstacle off-road. This causes the alignment to easily go out of spec when using the Raptor for it's intended purpose. The SPC Cams utilize a block off plate with a new eccentric to make aligning the truck easier, quicker, more accurate, and more durable.
THE SPECIAL:
We will align your truck, center the wheel, and install SPC Alignment Cams for $150
We will Level your Raptor using the OEM Fox Coilover snap ring positions, align the truck, center the wheel, and install SPC Alignment Cams for $350
Photo Credit Link:
http://www.fordraptorforum.com/f9/your-raptor-its-alignment-539/index12.html
Hasty
San Marcos, CA
I'm interested in the alignment and cams, is this still going?
Deleted member 12951
Guest
"We will Level your Raptor using the OEM Fox Coilover snap ring positions"
Is that another name for a mid-perch?
Guest
If that includes the mid perch, cams and alignment then its a decent deal. I paid too much at $600 but lifetime alignment. Yeah, I know again, paid too much.
