Offroad Alliance Fog Light Kits
OffroadAlliance.com
OffroadAlliance.com
Boston, MA
When @Miamibert and Velgen Wheels needed a fog light kit for their Raptor, only one kit would do! Our stainless steel triple bezel fog light kit gives you that OEM fit and finish. Capable of holding lights from all the best brands like Baja Designs, Rigid, KC Hilites and so many more. It looks awesome in these marketing photos.
Custom Wiring Harness
Our custom Raptor specific wiring harness is the industry leader for wiring up your lights. Our harness allows the user to control each pair of lights (and even the backlighting feature if you’re lights are so equipped) with its own aux switch for ultimate control of your lighting.
*NEW* Optimized Universal Triple Fog Light Brackets
Looking for a more open look? Our new optimized bracket provides the ulimate adjustability allowing the user to get the lights perfectly postioned to their own liking. Designed to fit three pairs of lights and are all completely bolt on for simple installation.
It’s your truck, light it up the way you want! We’re here to help answer any questions and make recommendations. With tons of lights available, and the best customer service around, you’re sure to find what you need at Offroad Alliance. So give us a call or visit us online today.
Ph: 888-466-8991
Online: OFFROADALLIANCE.COM
03'Darin
Harrisburg Pa
I've got to say I've been considering doing lights on my Raptor since shortly after I bought it. Which is almost 3 years now. Every time I start searching for lights and I'm determined to find something each time, I get overwhelmed with all of the options. So I end up giving up.
The entire time I've been looking at the light options for the bumper opening. Which of course complicates it even further with the 3 light option causing me to make even more choices.
During my searching this time I discovered the LP9 light and some videos show it's performance. I'm very impressed and think that's the light I want.
I have a few questions:
- I want to mount 2 of these lights towards the outer edges of the grille on each side but don't want to drill the bumper. Does anyone make a bracket or just a bar that allows me to mount them without drilling the bumper?
- I'm also alll about easy so I'm looking for a pre made wiring harness. I see that BD makes a harness but it's not built specifically for the upfitter switch leads (I can cut the harness and adapt it if need be). Do you possibly offer a harness thats Raptor specific for these?
- Any chance you can tell me if these will be on a Black Friday or Cyber Monday sale?
OffroadAlliance.com
OffroadAlliance.com
Boston, MA
The LP9’s are truly awesome lights. But they are also bigger and heavier than most. For the guys looking to run these on their trucks with OEM front bumpers, we typically recommend the N-Fab front bar. Wiring is easy and their harness is readily adaptable to the trucks aux switch wires with a few minimal adjustments. And yes, we’ll have some killer Black Friday deals on these, fog light kits and so much more!!!
Give us a call, we’d be happy to help. 888-466-8991
These are the LP6’s but you get the idea.
03'Darin
Harrisburg Pa
Damn that trucks got a lot of lights!! You probably see into next week when you turn all of them on!
In my search I did come across that n-fab bracket. I was trying to find info on how it mounts. It looks like you have to cut slots in the front bumper pads? Is that the case?
OffroadAlliance.com
OffroadAlliance.com
Boston, MA
That is correct
03'Darin
Harrisburg Pa
OK. Thanks. I think I like that setup better than anything else.
My other reason for 2 lights just on the outer side is that I don't want to block my front camera.
What are the chances that you could "leak" some BF deal info to me through PM???
I'd be looking at the harness, N-fab mount and 2 of the LP9 Pro's
03'Darin
Harrisburg Pa
Couple more questions:
Do the four lights on the truck interfere with the adaptive cruise and how much of the front camera view do they block?
Can I use one harness (splicing connectors for the other 2) if I want to run all of the lights on one switch?
OffroadAlliance.com
OffroadAlliance.com
Boston, MA
The camera is blocked some with four up front. You don’t lose the camera completely, but some visibility is lost. No issues with adaptive cruise control. You can create a custom wiring setup to run the main lights on one switch and we’d recommend running the amber backlight feature on another switch.
