There is no shortage of options when it comes to lighting for your Raptor. And we offer more brands and more configurations to ensure you get the perfect setup for your needs.
Mounting Brackets:
There's two basic brackets available today. Our bezel system and the universal mounts such as those made by Rigid, N-Fab, our universal bracket, Baja Designs, etc.
Bezel Mounting Brackets:
These offer 100% unobstructed forward facing lighting. They come in a double and triple light configuration. There seems to be a misconception that these aren't able to be aimed or adjusted. This is FALSE! You can definitely aim/adjust these lights. If you want to adjust the lights to the point where they are pointing sideways or very far outwards, this kit will not allow that. But with that said, you'll be lighting up the backside of your bumper if you adjust too much. Interested in width lighting? Pick up a set of flood beam lights or wide cornering beam lights.
Bracket Mounting Systems:
There's quite a few bracket mounts: Rigid, Baja Designs, N-Fab, Diode Dynamics, we make one called our universal bracket, etc. These brackets all use the exact same mounting points on the truck. They all come with slightly oversized mounting holes that allow minimal upward/downward mounting of the bracket itself. Some include predilled holes for mounting lights while some include channels. The holes/channels allow the light to be mounted more forward or backward. They are
ALL essentially the same thickness, very few are stainless and a very few are made in the US. Pricing seems to vary but ours universal bracket are the least expensive, made in the US and stainless steel.
Wiring:
We have a patent pending wiring harness that is plug and play for KC Hilites, Rigid, Baja Designs, Vision X and may others! No splicing required! Plug and play. It's so good in fact that our competition even copied our design. Want one Rigid, one KC and one Baja light? Not a problem we'll make sure all the right connectors are there. Our custom Raptor wiring harness quickly attaches to one, two or three auxiliary switches so you decide how to control your lights.
When you're ready to add some lights, we're your one stop shop! Triple fog light kits starting at $299.95 so we've got lighting no matter what you're budget is. Tons of stuff in stock so shipping is always fast.
Interwebs ---->>>
FORDRAPTORLIGHTS.COM
TRIPLE BEZEL KIT:
UNIVERSAL BRACKET:
