I found method 703s that are NVs without the bead ring have a 25mm offset. Just didnt like them over the NVs at the end of the day. Decided I would go mid perch and alignment route which i could probably use anyway after 7 years and looking at the wear on my current original STOCK tires. If I have to trim I guess Ill remember why I went this route. Thanks for the help everyoneYou will want to be at mid perch with 8.5"/0 offset and some trimming may be needed depending on which 35" tire you run.
I would still recommend mid perch with 9"/18 offset, but you could test it without first and see if there is any rubbing.
There is a thread that provides some higher offset options for 17s, but the selection is pretty limited. Icon & Fuel have some 8.5"/6 offset options that meet in the middle of what Method offers,
