off set and wheel size dilemma. Looking for some help
Jay Bee
iowa
2014 Scab
Stock everything. Not looking to mod anything for a wheel change-
Want 35x12.5x17 and method NVs. Curious about the rubbing
If necessary, method NV in an 18 has a 18 mm offset. But is 9 inches wide instead of 8.5, like the 17 inch version. So not sure if that is a wash
1/4” on inside and out, ideally in addition to the -16mm offset given up (gen2 - what was gen1 offset?) I just did +18mm / 8.5” wheels on my 2017 and it’s definitely a little tighter at full lock, doubly so if you have mud flaps.
J
Jay Bee
iowa
gen 1 offset stock is 34mm
J
Jay Bee
iowa
so my options are 17" wheel 0 offset
18" wheel that is 1/2" wider and an 18mm offset (or 0 if chosen), but probably fits like 12mm offset after width adjustment
No 18mm offset for the 17s
18mm is .7 inches.
going from 34mm back to 0 is almost 1.5 inches inward correct? guess i will be making 6 point turns.
going with ridge grappler which isnt overly aggressive but is no slouch to the mts
J
Jay Bee
iowa
maybe the extra 1/2" width of the 18 wont matter because the tire is the same. So 18mm offset and around 3/4 difference on the 18s and 1.5 inches on the 17s
Have mud flaps.
J
Jay Bee
iowa
about $300 higher price to go to the 18 set up for wheels and tires. not sure on the gain or loss in weight of the 2 combos. Negligible daily but adds up over time
J
Jay Bee
iowa
Would mid perch solve any minor rubbing? not opposed to that
good question. A little extra elevation up front probably would help but, I can tell you there not a butt-load of full lock clearance regardless. I don’t think 00 offset will work without trimming.
HORN HIGH ACES
Colorado
You will want to be at mid perch with 8.5"/0 offset and some trimming may be needed depending on which 35" tire you run.
I would still recommend mid perch with 9"/18 offset, but you could test it without first and see if there is any rubbing.
There is a thread that provides some higher offset options for 17s, but the selection is pretty limited. Icon & Fuel have some 8.5"/6 offset options that meet in the middle of what Method offers.
B E N
Frederick, CO
I run a 9 wide +18 offset and will get rub at mid lock. This is with a stock size Duratrac on bottom perch. You may be able to dial in a little extra caster to get away with it, but as @HORN HIGH ACES mentioned going to mid perch will be your best bet.
