OEM (The Real Deal) Rain Sensing Wipers discussion
Svtweb
Svtweb
Westminster, MD
what sucks is when there is morning moisture on the glass and you start the vehicle before you close the door. you pretty much drown the drivers door panels
2nd on that one bud.. While I understand the door design to reduce wind noise, I had that if there is any precipitation on that vehicle, frozen or liquid, when you open the doors, you coat the outer 4" of the seating surfaces with said precipitation.
MTF
Celebration, Florida
LOL, Don't forget the first right hand turn with precip on the roof and you have the window open any amount.
I won't even mention, well.....yes I will, lifting or opening the sunroof and forget about all that precip.
Jordan@Apollo-Optics
aka <b><font color='darkorange'>LSUstang05</font><
I wouldn't mind installing a momentary switch somewhere near the steering column that, when pressed, would cycle the wipers one time. This would help when offroading and I get a mud/water splash on the windshield and need to clear it really quick.
Do you have a front camera on your truck? If yes, you may run into some troubles because I believe the wipers are controlled through the SCCM (Steering Column Control Module) through HS-CAN and the module is probably different on a front camera equipped Raptor because of the front camera sprayer.
---------- Post added at 02:26 PM ---------- Previous post was at 02:16 PM ----------
Emailed you some info... hope it helps.
Just tap the Windshield Washer button on the end of the stalk. If you just quickly press and release, it will do a single wipe. If you press and hold, it will spray and then wipe multiple times before stopping.
Courtesy Wipe is for after you clean the windshield with washer fluid. Once the wipers are "done" it will pause for a few seconds and then give one last wipe to get any fluid that may come back onto the windshield when driving.
