OEM Screen brightness
faultball
U.S.A.
Wondering if there was any way to drop the brightness at nite, already at the lowest setting with the dimmer. Would anyone know if Forscan has a way to do this?
tia
DanT
North Texas
I’m assuming you mean you’ve already switched it to night mode? If not, this may help.
If so, I don’t have an answer.
What version is your system? I don’t have the additional adjustment under AUTO
Traffic22
SF Bay Area
I’m not 100% certain, I believe it is 3.2 or something similar. But I’ve owned a ton of Ford’s since sync came along and even sync 2 had a night mode.
I’m not sure what’s going on with whatever version you have. My only other suggestion would be to download any available updates via the Ford site and do a USB update. (I’ve never been able to get OTA to work)
DanT
North Texas
Thanks and agree - after seeing what was in the video - I checked sync in truck and it said current. When I checked online with owner.form.com it said there was an update available - go figure. Will download to USB and update manually. Appreciate your assistance!
Traffic22
SF Bay Area
Good luck, hope the night mode becomes available for you.
goblues38
STL
I have mine at the lowest setting in the screen and the dimmer by the light switch. BUT...I have found in both my raptor and my explorer......the dimmer by the lights don't "stick". if I bump them up one note then down again...it goes back to the full dimness I wanted.
95,505
59,113
SK Raptor R
