OEM Ford Raptor Steering Knuckle Part #s:
Big Blue
Administrator
Staff member
Admin
USA
Hello All,
Just wanted to post this up as I'm sure someone else may need a set for replacement or as a spare.
There are 3 versions listed, but the Raptor versions are Parts #;
Left side: AL3Z-3K186-D List price: $173.73, Tascaparts.com price: $114.66
Right side: AL3Z-3K185-D List price: $173.73, Tascapart.com price: $114.66
Sano Dano
Encinitas, CA
Knuckles
I ordered the stock F150 knuckles, they are about $20 cheaper each, only difference is you will need to tap a few 6mm holes. The caliber bolt holes are the same size.
I added the gusset kit from Outlaw and drilled out the top mount from 5/8" to 3/4" to mate with the RPG UCA.
Sano Dano
Encinitas, CA
Installed my new Knuckles today.....with new 3/4" 12 point bolts and spacers, Minimum tensile strength is 170,000 psi on the bolts.
Had to grind about 5/16" off (note screwdriver in 3rd pic) to clearance the spring on the FOX 3.0s. You can see the issue in the 2nd pic.
Mil T
Payson, Az
Looks good. How did you do the welding? Mig, Tig, Arc?
Were the braces actually hitting the spring? Kind of weird. I didn't have any problem with that at all when I did mine.
Nice job you did.
Mil T
Sano Dano
Encinitas, CA
Nice job you did.
Mil T
At full extension they were hitting the springs....Talked to Connor at Outlaw, he though that maybe FOX had changed the springs on the new 3.0s, has a call into them to see, but not likely.
I had them Tig welded....
TXRPTOR37
Does outlaw sell there gussets welded to the knuckle for additional $$ or are you on your own to figure out who can weld them?
