B E N
Could be leftover casting sand. Flush, fill, monitor.
Is the cap magnetic? Bet that has been there forever. I only like the French Vanilla from Timmies, I feel like a jennie when I go thru the Starbucks drive thru for my Pike roast, lol.Nothing under oil cap, nothing in overflow tank all clean.....This is what is stumping me.... Corona...timmy hortons far better than starbucks. I think she needs another look other than what I have. Ricoman, I hope you are wrong, but I always prep for the worst.
The lack of Contamination in other areas leads me to believe this is either the Rad itself with the P/S cooler lines in it or the waterpump itself.....yet no higher temps.......
You need help!!I prefer McDonald’s coffee.
Oddly enough like I said I did the flush 9ish months ago....was going to grab some Motorcraft Orange, go to my dealer give them my vin, expecting orange......well they switched it to yellow, thats what I have in her now. Just called ford again to confirm it wasn;t my idiot dealership again they confirmed yellow!Did you replace the coolant fluid with right color for your year.
I posted the coolant chart from Ford somewhere on the forum.
Also I've seen issues with using auto part store or aftermarket brands that say it's compatible with types of fluid.
But there not.
I only use Motorcraft and there is a change it color too.
https://www.motorcraft.com/content/...erence_charts/antifreeze_coolants_english.pdf
You need help!!
