2013 130k miles having intermittent issues.
It will have low idle (500rpm) when stopped which makes it shudder when easing off the brakes.
While idling it will randomly die with no CEL's.
During highway speeds it will shudder, like a fuel mixture mistake. Other times while driving around it will go into limp mode throwing codes P060A, U0300, P1674. It goes away when cycling the ignition and runs perfect again.
I have replaced the canister purge valve, cleaned the MAF, checked fuses & relays, pulled & cleaned “major” PCM plugs, changed spark plugs, fuse 27 mod, air filter is clean.
Thank you for any helpful information.
Update: Cleaned throttle body, replaced coil packs & ignition wires. Runs great now
