Engineer90
That sure is a general question. How does one answer that? Yes, No, Maybe?
Let me ask you, says you're in Maine. Aren't some trails tight there?
Yes I'm actually looking into the extended cab one, the crew cab is too long imo. Plus, the wheelbase is only 6" longer than the Taco's
True the SCREW is the similar to the Ram Mega Cab, Ford's F150 extended cabs are longer than anything in its class as far as trucks go. The thing about the Tacoma is that it will be more narrow on the trails that you are talking about and how will you feel once you scratch the side pant on your expensive truck? Makes a difference having something that you can throw around more and not care what happens to it.
This is why I’m having my doubts. The 6-speed auto in the Taco is weird from what I’ve read. I would love a manual but it’s not offered in the access can TRD OR. Plus I feel like it needs more power and torque.So I came from a '17 Taco to a '19 Raptor. My initial mistake was that the Taco was an Auto as if it were manual I might still be in that truck. The auto transmission gearing is horrible, the engine lacks any grunt down low and demands you rev the **** out of it, and you HAVE to swap out the tires immediately for something better if you want to hit the dirt. Max size at stock height is like 32 and maybe a 33. To even fit a 34" is a lot of work with shock and springs, needle bearing replacements, re-gearing (you need it larger than a 33" tire) and cab mount frame chop.
Swapping to the Raptor I have zero regrets. Sure its more expensive but out of the box I literally didn't have to do anything at the get go to get me out in the dirt. Plus the daily driver aspect is night and day. It doesn't struggle to move its big butt, super nice ride around town and when you lay the hammer down it brings nothing but smiles.
I bet that 10-speed is a huge improvement in the Raptor right? How’s highway comfort?
5th and 6th gear are basically overdrive gears. The transmission would continuously hunt gears even in the slightest incline from 1k rpm to 3-4k rpm cruising at 45-50 mph. It was maddening to say the least.
Some people don't like it but I think it's smooth as butter considering what I came from. The Raptor floats on the highway and you will be speeding before you know it. Bumps at speed? Don't care. The Raptor just eats it up. Sometimes i purposely hit pot holes just because... lol... The only thing I say you gotta pay attention to is the rear end on the Raptor. If you get a new one make sure to adjust your tire pressure. I run like 36-38 front and 34-36 rear. Helps keep the back end from stepping out on you, but you can always run around in AWD mode as well.
Wow. Did it do this even with the software update? I know a lot of guys in the forums said their software updated helped a since it was a huge issue in the 2016 models and such.
Will keep in mind if I do get it. Plus make sense since most of the weight is in the front.
NJ has really bad roads, I am sure the Raptor will have no problem absorbing any potholes or bumps
