No key detected issue
The Car Stereo Company
here, on frf
you will need to trace the wire back somehow. not sure how apart this car is, but the antenna wires are usually paired together. signal and ground/shield. you can at least check the first connection at the antenna itself. usually theres a connector near by. check both ends of that then if thats good, trace those wires to the module. might require some disassembly, but its part of the elimination process to find your issue.
Sage
WA, dry side
If none of the buttons work, are you positive batteries are in correctly? Only one fob or 2?? Both don't work?
G
Gintys
Lithuania
I only have one fob, and if the batteries would be incorrectly, I think it would not work in the backup programming slot aswell
FordTechOne
Detroit
Did you program the new RTM or just install it? It requires PMI with a scan tool when replaced.
