No-cut hood mounts comparison
Jay9722
ATL
I have the AO mounts and after a little trial and error doing it myself I got them on and have zero complaints. If I had to do it over again I would get another pair of hands to start and also remove the left and right wiper cowl to avoid bending/cutting the plastic. I did end up buying new cowls since I notched out part of the originals to make room for tools. I have no vibration with 4.5 Apollo Optics on the mounts. They look great.
ntm
Alberta, Canada
The sdhq mounts are a bit thin for heavier lights. A friend has them with larger rigid lights, and they vibrate around quite a bit.
Drunktank
Seal Beach, CA
Whatd be REALLY nice is if these guys put slots in the mounting holes so you dont have to FULLY remove the bolts. Just loosen the bolts up a quarter inch... slide the bracket under... tighten down. Seems like itd make install a lot easier for one person. Sure, youd still have to align the hood bracket... but at least itd still all be held together.
Bussy
Bussy
MN north metro
The install was a bit easier only because it was a second time around. I do feel that a favorable difference is that the @SDHQ mounts have more clearance from the hood and side panel. Next step will be to check for vibration.
FireLT
I have Vision X 4.5 cannons and AO mounts... The AO mounts are super strong and dont look like they would budge or vibrate after installed...
