GEN 2 Night Vision Camera installed
EastEndAngler
Long Island, NY
Another gadget added :) Always thought there is a final project - again proven wrong - there is always an project this time i added an Night Vision Camera Set - pretty cool
View media item 15229
and Grill mounted:
View media item 15230
This post sent me down the rabbit hole...... Austin Weiss ran one of FLIR cameras on a build he did a few years back and I always thought it was super cool. I live on LI and it gets DARK, we've also got huge deer populations that don't seem to understand the concept of self preservation.
I was actually trying to figure out how i could run something like this without an external monitor.
Does anyone have experience with this module? You get an extra video input and video in motion:
https://naviks.com/i-24075926-2016-...v3-4nav-in-motion-bypass-video-interface.html
Swarfworks
Michigan
I’ve been running one of the Flir PathfindIR 2’s for about a year and a half. It rocks. I have it integrated into the factory head unit.
I also have one of the hudway displays on order. They’re only a year behind schedule as you probably know. Ugh.
I should buy one of their thermal cameras like you bought to compare. I wonder what the refresh rate is. Guessing it’s lower than the Flir’s. I had to submit paperwork for a background check to homeland security to buy the Flir, I believe because of the 30fps. The animal and pedestrian detection on the Flir is where it’s at.
lateralis
Oregon
What's the range of these cameras and what is required to wire the camera like the Flir into the stock head unit?
Darthyota
Alberta Canada
I'd be willing to bet all these systems use the same FLIR camera as FLIR will sell those as a component to integrate into a custom camera system
EastEndAngler
Long Island, NY
@Swarfworks - just had to say - killer fab work (love my license plate bracket). How did you go about getting an aux input for factory head unit?
Fender
Wow i didnt know running such a camera needed clearance application
Swarfworks
Michigan
Range? Well I can see the temperature difference of the clouds in the sky, and the level of water in a water tower. But to pick out a deer in the middle of the road in ideal? Shoot I’d say 1/2 mile at least.
I don’t know about that. I think the Hudway one is a knock-off of the Flir. They’re sourcing their other parts in China. I don’t know why Flir would make parts for them to undercut their own sales. Hudway unit is $1500, Flir is $2,500. But I still wonder about the fps rate of the Hudway one. Flir sells an "exportable" version that I believe is around 8fps instead of 30fps. After having 30fps, 8 would suck.
Thank you! So the integration is the trick if you don't want a separate display. I'm running a prototype unit of NavTv's COD (camera on demand) module. It allows you to use the factory cameras at any time. This unit also has an auxiliary input, which I connect the Flir's output to. But what makes it even better, is I'm also running their Flir-XW (eXternal Warning) module which when the Flir "sees" an animal or person, it triggers the COD module to activate, as well as sets off a buzzer.
Now the whole this is super awesome. It's one of my favorite mods. But it isn't perfect. It doesn't work when it's snowing, heavy dust or fog (which the Hudway one is falsely claiming it will). The camera is just measuring the temperature of the moisture, or dust, particles in the air. It's not radar and can't "see" through them.
I also get quite a few false alerts with the AD/PD (animal/pedestrian detection). It uses algorithms to determine if there is an animal or person. So it if "sees" a sign that is tall and skinny and the sun was hitting its roughly the same temp as a human, it might alert. Not a big deal as that usually only happens in the daytime. I ended up putting the XW buzzer on an up-fitter switch.
The FOV is also fairly tight. Which is good on the highway, but would be nicer if it was wider when going slow.
Anyway, think that's all for now.
Paul
pastorwug
Santa Maria, CA
These units are not hundreds of $$ they are thousands of $$.
Nice and fun to have but quite low in my mod list.
Though, I'd like video at all speeds if that's possible with an add-on.
