Ok dumb question, but can you fit 35x1250/17 on the stock rims? And if so is there any rubbing? Also if moving up a rim size to 35x1250/18 is there rubbing? I looked up on one of the tire size calculators and came up with this. This is Stock, +0 and +1.
315/70R17
Section Width:12.40 in 315 mm
Rim Diameter:17 in 431.8 mm
Rim Width Range:8.5 - 10 in
Overall Diameter:34.36 in 872.74 mm
Sidewall Height:8.68 in 220.47 mm
Radius:17.18 in 436.37 mm
Circumference:107.9 in 2740.6 mm
Revs per Mile:605.3
35x12.50R17 (318/71R17)
Section Width:12.51 in 318 mm
Rim Width Range:8.5 - 11 in
Overall Diameter:34.77 in 883.15 mm
Sidewall Height:8.88 in 225.55 mm
Radius:17.38 in 441.45 mm
Circumference:109.2 in 2773.6 mm
Revs per Mile:598.2
35x12.50R18 (318/67R18)
Rim Diameter:18 in 457.2 mm
Sidewall Height:8.38 in 212.85 mm
Radius:17.38 in 441.45 mmCircumf
Revs per Mile:598.2
I got this info from
Tire Size Calculator - tire & wheel plus sizing
