grantoser
- Joined
- Sep 26, 2012
- Posts
- 249
- Reaction score
- 68
Just ordered wheels. Went with Fuel Mavericks instead of waiting for the novakanes. Went with a 18x9 1mm offset. Should stick out there just the perfect amount. The wheels look like this. I think these will look very sharp on my blue scab with black hood/side graphics.
These are 20s, not 18s... And the tires are 35s, not 36s like I'm going with. But this gives you an idea of what the wheels look like on Toyos.
---------- Post added at 09:11 PM ---------- Previous post was at 08:57 PM ----------
I would think you'll have plenty of clearance still from the garage. Technically the 36 inch tires should only raise your truck half and inch... (36-35=1, 1/2=.5). Definitely can tell a major difference tho... In person and even in the photos.
Might want to check around about going with the methods. I leaned away from them because I thought the +18 offset might not be far enough out to clear the much meatier tires. I ended up going with +1 just to be as safe as I can. Not sure tho you might be in good shape... Would love to see these on some methods!
I do think we'll both be pretty good height-ways with clearance. If guys are running 37s with stock fenders and just barely rubbing I would think we'd have quite a bit of clearance left with 35.7s!
those look great. i've been looking at that same tire for some time now. in the pics they look taller than i was expecting. i hope i can still fit in the garage when i install them. i have about 3 maybe 4" clearance on stock tires and mid perch so i should be ok. and once they are on and 3 tons pushing down on them should still have an inch to spare. i'm looking to go with method nv's in 18x9 with a +18 offset. they are also backordered at the moment though so if you're in a hurry to install might have to branch out from method and bmf.
keep us posted and post pics and updates on fit (rubbing, noise, wear, etc).
thanks in advance!
