New products! Raptor A-Pillar Lighting Kits
Baja Designs
Baja Designs' F-150 and Raptor A-Pillar Kit is your ticket to prolonging the day! This kit gives you the option to run our Squadron Series lights. Installation on this kit is simple, and the design is rigid to make sure that there are no vibrations even when you're running down wash-boarded roads. If you're looking to spice up your truck and get more out of the day this kit is for you.
Available HERE
No Lights - Vehicle Specific Mounts ONLY
Sport - Vehicle Specific Mounts & Squadron Sport, Pair
Pro - Vehicle Specific Mounts & Squadron Pro, Pair
mpk1996
Sweet. Just ordered a set of the hood mounts, but for a pair of amber s2s. Should look sweet!
mpk1996
6A5C00A9-FC36-40CC-A870-829F3D2D2247.jpeg 96203DC8-5FF2-48EC-AEEE-010DBD473CB1.jpeg Got the A pilar brackets and s2 lights installed.
First of they look great once installed. I really like how low they are to the hood.
The brackets are well made, but really have a few issues that should be addressed.
First, having 2 washers as spacers that need to go between the bracket and the hood hinge is a horrible design flaw. Now maybe in a shop with a pile of guys to install this ends up being ok. But trying to line up the bracket, 2 washers, and the hood hinge is very difficult. On one side (depending if you are left or right handed) will prob go reasonably easy. But the other will be very challenging. There should be a properly sized and machined spacer. Ideally already mounted on the bracket. I get that may not be perfect as there need to be some float to get the hood lined back up.
Also. If there were a cut out on the angle side (with the spacer attached) you could install with out having to completely remove both hinge bolts and having the hood (and hinge bracket) moving around so much. I would have gladly spent an extra $20 or so to have a much simpler and faster install.
Anyway. In the end I got them all installed and everything aligned back up. They look great!!
Baja Designs
Baja Designs
Want to save some $$$ when purchasing any Baja Designs product?
Enter Coupon Code: BDForums at checkout to save 10% + have the option of $5 shipping
Check out some of our favorite products below!
https://www.bajadesigns.com/home/shop_products_categories.asp
We have everything covered from cars, trucks, SUVs, ATVs, UTVs, Motorcycles, and more!
Baja Designs
www.bajadesigns.com
