Rear facing lights are required on many Raptor runs, and if they aren't required, they are highly recommended. Those of us who have been flying down a dusty road at 80mph know the piece of mind it gives you to be able to see a truck in front of you through the dust. They are also nice when backing up in the dark or at night when you have a Prius tailgating you.
Here is our solution...these are made of a single piece of 6061 aluminum and powdercoated black. Installation is easy...simply place in the corner of the bed, mark the holes and drill through. You will need a rivet gun and 8 3/16th long rivets (available at Home Depot or Lowes) to secure the mounts.
The mounts work with most any light...they were make specifically the TMX Blackhawk X1 or the Rigid Dually in mind. Both the TMX Blackhawk and Rigid lights come with a lifetime warranty.
TMX brackets: $50
TMX brackets and pair of white TMX Blackhawk X1: $149.95
TMX Brackets and pair of white or amber Rigid Dually: $239.95
TMX Brackets and pair of white or amber Rigid D2: $407.95
TMX brackets: $50
