Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Welcome, and so glad to have you. What mods are you thinking of doing? There is so much help and experience just chomping at the bit to assist you here at the FRF!
I am going to be installing a Auxiliary External Oil Pump. The two reasons are to Pre-Pressurize the block prior to starting, and the second reason is I read that the 6.2 has Oil Pressure issues at extreme or steep angles. Since this pump feed from the Drain Plug it would keep pressure on the block regardless of angle.
