Hey guys thank you for the feedback! I'm waiting on some mods to come in and I'll post more pics, here is a new pic with the rims painted in black.
Thank you Nick, I appreciate it! I think you're right it may depend on the mirror options (from what I've found so far).
Thank you! I think I've figured out the Forscan part I just need to figure out which mirror options I want and if I should add the BLISS feature or not (the below link kinda motivated me). If you by any chance come across that thread again that would be great, I'll look for it in any case.
I found this guy that basically did everything himself (BLISS mirrors, 8'inch cluster screen etc)
Yes, the car is dealer spec'd and everything is OEM.
The truck was in the desert hence the dusty interior. It's been fully detailed now and looks as new from the inside (will post some pictures later).
Welcome aboard and congrats on your new vehicle!
The mirror swap can be done. It will require new mirrors, new window controls, and some software changes with Forscan. You may also need to make some wiring adjustments, too. But I'm not totally sure on that one. There have been guys who have installed Tow Mirrors so you may want to search those threads and see if you can find what you're looking for.
Look on u tube , a guy posted a vid with part numbers for the auto fold mirrors. You will also need door modules , with the harness. On f150 forum is also a big thread on the subject. But the video shows everything but the forscan part. Insert value from a truck with power fold mirrors first to turn on modules then insert values for Lincoln mirrors.
Just curious, does your heated seats work? If not then the previous owner added sync 3. Its a plug n play mod for the 18s , 17s had different plugs and need a converter harness.
You may want to invest in some armor all wipes and get that dash cleaned up...
