I had an issue going on that you probably won't have to deal with. I installed the gasket and bracket on the driver side with no issues.
So then I installed the gasket on the passenger side and got the bracket in place with the bolts started. As I tightened the bolts the top inboard corner of the bracket would push the top corner of the gasket off the lip and if I continued to tighten the bolts it would damage the gasket. So after 3 gasket and bracket removals and re-installs with the same results I took my cool down break.
When I went back out... I installed the gasket and put some dielectric grease on the top corner of the gasket and the top corner of the bracket and that time the bracket slid over the gasket without moving the gasket out of position. Just as I got the bracket tightened up my phone rang and it was Jeff. He must have read my post and was calling to make sure everything was ok. Talk about outstanding customer service.
I probably should have hit him up with a few more questions while I had him on the phone.
