NEW - Baja Designs Combo SPV Rear Hitch Light Kit - Plug N Play, Removable...
Specialtyperformanceparts
Previously, we kitted our Pat Pend Hitch light kit exclusively with the Rigid D-Series Flood light.
Due to demand, we are now offering it with the Baja Designs Sport Wide Cornering Light.
This Plug N Play option allows you to slide a reverse light into your hitch receiver when not in use and simply plug it into the 7 pin connector. From there it's automatic. When in reverse, you have extra backup light. No installation needed to the truck. When you have a trailer, unplug it and throw it in your back seat...
Check it out here...
Possibly? But since there isn't power draw all the time because only the revers wire and ground are connected. There may not be a signal for that. It isn't something we checked. I can try to check here in a bit.
John
