GEN 2 Need Transmission rebuild/replace. Recommendations on best route?
scary gary
California
I believe I do have some recollection of that previously being mentioned. Someone can correct me if I’m wrong, but by flushing the transmission, it causes all shavings/particles to get pushed back of the trans and causing failure shortly after x time/miles.
I have heard of mechanics(non-dealer) that drop the pan, replace the filter consecutively (I believe twice total)to get most of the gunk out. I don’t know how much truth holds to this or the effectiveness of it.
But I’m glad it was all documented and you were able to get it replaced at no cost! 13k is a pretty penny to pay.
Thank you for your reply!
Exactly. It dislodges debris and then ends up in the cooler and converter. After my service the truck made it 400 miles. The dealership blamed it on a over fill. Then truck then made it 100 miles. It would be bang into gears and some times feeling like I’m rear ended and slipping in all gears. Blows fluid out all over the truck. I could drive around town no problem. But after driving about an hour would it start to act up.
F
FrankL1
Ca
Good afternoon everyone,
I’m sorry for the delay in response/communication. I’ve been back and forth from the desert due to work. But now that everything is coming back to the valley. It’s mellowing out.
I wanted to update everyone who’s been supporting. After back and forth, really no avail I replaced the transmission.
I went to Ford at Paso Robles, they had the truck in and out with about a week or so. Transmission got there second day but had to order some hardware that made the transition a little longer. Original Ford dealership where they took it apart had all the bolts in a box and Paso Ford took a while to sift through it to make sure all was there. All said and done, it was about $6,500.00 otd. It would have been less by $250.00 but it needed a new battery.
For the price, and customer service they provided, I’m happy.
Fred at Parts and Tyler in Service were great to work with. Answered all and any questions that I had.
For reference:
Lithia(I think) in Fresno quoted me $6,400.00 parts and labor(Transmission being at $4,100-$4,200) which I think that’s a great price for the unit itself from all the calls I originally made to a dozen of dealerships.
But then I factored in the cost of hauling it on the gooseneck with the 5500, plus time taken away. Thought it would come out more expensive in the end. So I contacted Paso and Tyler said they were happy to match the cost (and the $400.00 off for already being disassembled), so I went with them.
The only service I denied at Paso Ford was the cv shaft replacement. They quoted me at $1,372.00 or close.
my personal mechanic (whose a reputable shop owner) and our company mechanic both seen the shafts and both stated that the inner boots were popped off and not damaged. My mechanic stated once the truck was out from Ford to take it in. He’d take out the shafts, inspect - and if there were no issues, repack and utilize the same boots with new clamps.
The shafts are in working order and have no issues. But the boots popped off again in one of my farm visits (normal dirt driving).
Stated that Ford does not sell the inner boots (or outer) but do provide the clamps but $90.00 a piece.
Said he can rework and clamp with OE at $320.00 but there can be the possibility of them coming off again.
He quoted me $700.00 or just under for labor and new CVs, so for the price difference I’m going with new CVs. Should be done by Thursday.
Hopefully anything I posted can be resourceful.
On a side note, as always, dealerships want their core. In my case, it was in a ton of pieces. So I took two afternoons and a few 805s and put the transmission together. No diagram or video. So to thee best of my knowledge it went well, all internals spun and interacted just fine within itself. So if it was put together how it should - I feel pretty darn proud.
Donovan
DC
So here I am in this thread lol....
I found the internals for the diff to be rebuilt. How seeking the internals for the trans to be rebuilt.
swgaraptor
Georgia
New to site
2020 raptor purchased clean at 36k had 3rd party check everything all stock no mods all road miles some field miles- well taken care of…
About a month ago, no reverse, grinding whining with gas and foot off gas. Sometimes will not go back into park.
Still would drive it and run fine, recently the reverse will stick and not move in reverse.
Ford dealership scanned everything checked it all out, per Tech
Recommend new trans at 7500 labor 2500
Do not drive
Had it towed back to house, been driving around farm, no higher than 45/55 mph occasionally will stick and no go in reverse, wait a few minutes turn off back on, drive a mile or 2 and try reverse and it works…
Has 62k on it, trying to decide if trans is worth it/ trade in/ is it trans?
Love the raptor but sounds like it could be an expensive fix and may fail again…
No warrranty
Any thought ideas appreciated
Thks
Greenwood, IN
New to site
Do not drive
No warrranty
Thks
I recommend you start a new thread if you want helpful responses. You may also want to post an introduction with a picture of your non-prius. I feel for you, a bad transmission during Covid is what got me into a Raptor. There is a lot of expertise here.
FordTechOne
Detroit
New to site
Do not drive
No warrranty
Thks
If it won’t go into park that’s 99% of the time a shift linkage issue. Start by inspecting the shift cable on the side of the transmission for damage. Who knows what those “field miles” consisted of…
91Eunos
Hill country, Tejas
Well, the ball’s rolling…
Truck’s getting the a/c evacuated right now, then home to get it up on the lift to drain fluids and pull the driveshafts.
Busy all day tomorrow, but will start the cab removal Friday. Want to get the transmission shipped to Tier1 by Monday… they don’t have any suitable cores in house right now, so they’re just gonna rebuild my transmission.
I plan to drive out to Phoenix in mid-January to pick it up… With a stop by Full Race for some engine goodies OTW back home with the nee transmission!
