Need help trouble shooting
Wfo
Syracuse
a few weeks ago I installed a full race radiator and transmission cooler. It’s been running hot so today I drained coolant and used the vacuum fill method, Still same temps. It’s 70deg out and truck is jumping up to 210+. When I feel the lower hose on the driver side it’s cool, just above the double inline T that has 2 hoses going to the side of the oil filter it’s hot as hell. The hose on the passenger side is also hot. The driver side rad end tank is also cool while the passenger side is Hot. Full race and I are stumped. Could it be the thermostat? All ports / nipples were clear before I did the install. Can anyone offer advice? It’s a pain in the ass to change this out to the oem rad.
FordTechOne
Detroit
Just throwing this out there...the radiator fans connectors are plugged back in right?
Rappie
Could be air in the system. Try bleeding the system to release the air pocket.
Sent from my SM-G965U1 using Tapatalk
Blown00gt
Arkansas
I would guess air bubble take the cap off and get it up to temp. Could be T-stat you could always take it out and put it in hot water on the stove and see if it is functioning.
jabroni619
A new radiator alone isn't going to drop temps if you're using the stock thermostat. Think of it as a pressure regulator on an air compressor. If it's set to 40 PSI, it doesn't matter how large of an air tank you get, you're still going to get 40 PSI. You just have a lot more coolant now before heat soak sets in.
