ActionJaxon
Were those the SVC extended shackles or a different brand? Thanks.i installed a set of their line longer shackles and it lowered the rear of my raptor approx 3/4”
Appreciate the help, talked to them yesterday and they dont like extended shackles for similar reasons to what you’ve listed.SVC doesn’t endorse extended shackles, claim they cause binding
all other shops seem to like extended shackles for more droop travel or to lower
remember if you offroad and want compression travel to avoid bottoming and frame damage then a taller or stiffer spring is advisable
even an hydraulic bump kit can be damaged if there is insufficient uptravel and regular deavers can be flattened with hard use… I did both
rpg migWere those the SVC extended shackles or a different brand? Thanks.
Awesome, thank you much!rpg mig
'15+ F150 & '17-20 Raptor +2" Extended MIG Shackles
RPG Off-Road Fabricated Shackles for your 15+ F150 or 2017-2020 Raptor. Increased articulation and improved performance. Manufactured in-house in the USA.www.rpgoffroad.com
