Droid
kglesq's Brother
- Joined
- Sep 25, 2010
- Posts
- 1,486
- Reaction score
- 757
I just discovered the navigation unit's "bezel diagnostics" feature.
To enter it, hold down the "3" and "6" preset buttons. It will begin a speaker test. You can end the speaker test immediately by pressing the "end test" button in the lower right corner to proceed directly to the "bezel diagnostics screen". Or you can wait for it to finish.
The bezel diagnostics screen looks like this:
The "View DTCs" option appears to allow you to view and clear *real* OBD2 DTCs. At first I figured this was just for nav or BCM codes, but googling a bit seems to indicate that these are actually PCM DTCs, i.e., check-engine-light producing OBD2 codes. At least that's what these superduty-oriented folks think: Ford voiding warranties for adding performance mods? - Page 2 - Ford Powerstroke Diesel Forum
Can anyone with a check engine light verify that this is the case?
I can't believe no one has posted this before. Quite the awesome feature if it works.
