nav-tv front camera/vim bypass
btizzle
I just ordered a '13 with a front camera. Can do I get in on the group buy for this thing?
Also, how do you switch to front or rear camera when driving normally?
mwright4679
Syracuse NY area
the front camera works the same as prior to bypass
the center display (between rpm and speed) scroll down to truck apps and one of the options there is for front camera. With out the bypass you have to have truck in off road mode and rear diff locked then you hit the ok button and the nav screen will show the camera up to like 5 mph. with the bypass all you have to do is hit the ok button and it will come on. no need to have off road mode and rear diff locked. also the camera will stay on no matter how fast you go. the only way the front camera wont stay on is if you put in reverse. Now when using the "bypass" you will loose the steering lines. steering lines are blue lines that show up and let you know where your path will be depending on how the wheel is turned. If you use the camera like there is no bypass (off road mode and rear diff locked) you will then get the steering lines again.
the reverse camera you double push the rear defrost button and it will show up. Now there is a small thing with this... if you use your rear defrost, when/if it times out on its own (or you manually turn it off) the rear camera will come on. It doesnt appear that there is a time setting on the double push. you can push the defrost button one time and then 10 mins later push it again and the rear camera will come on.
Also with the bypass you can use all your functions of the nav while driving down the road. Now in order to do this you double press the regular defrost button 2 times.
Hope that makes since. if not let me know and i can explain further.....
Rookie
Fort Wayne, IN
Kind of an odd setup using the rear defrost button. I think I'd rather it have its own button than use another one already in use.
mwright4679
Syracuse NY area
it really isnt much of an issue.... Playing monday morning quarter back i would have used a different button for rear camera just from what i listed above. these units are upgradeable so maybe the Nav Tv guys will see this and change something....
Beats do you have a bypass already?
Rookie
Fort Wayne, IN
No I do not. Was going to talk to Noah about ordering one but it's not at the top of my list. I will probably knock out audio upgrade, bypass, and painting the trim pieces all at once.
