pat'sRAPTOR
Sell it that'll fix the problem lol
guys….I´m only putting 95octane in it constantly :-D I had 98 octane and 100 octane once…I also had E85 once…very bad.
But honestly, what else do you want to throw in your engine but a 100 octane to somehow clean it?! :-D
Hell no - I´ll never sell it!Sell it that'll fix the problem lol
as I wrote earlier I didn´t have my foot on the pedal when I gave the raptor the first try in the morning. the video on my phone was to long so send it to the computer thats why the first start is missing. The first try is always the same - turn the key, let him crank....nothing happens, he´s not firing up. The manual says if you have start problems and u have to try more than once to start the car push the pedal at least 1/3 while cranking....I don't think that this is the cause of the problem, but it may be making it harder to start than it would otherwise. Do not put you foot on the gas pedal when starting. The CPI knows what the engine needs for start-up better than your foot, and you are confusing the matter by pressing the gas pedal. I think it's why you smell gas.
Intermittent problems are notoriously hard to diagnose, and one that's temperature sensitive can only make diagnosis even more of a challenge. Given your climate, I think it would be quite prudent to install an engine block heater. With temperatures like you've described, this seems like a gimme to me.
I’m having the exact problem with my 2010 5.4 Raptor, anytime it’s below 25 degrees F. Just bought it a month ago, seller said use 91 octane fuel. I downloaded the manual this morning, it says use 87 octane. Now I’m researching octane, it sounds like running too high octane will cause hard to start when cold. Not sure if this is the problem, but I’m running the tank below 1/4, then filling with 87 octane. I’ll post in a week if this helps.Hi guys,
I know that there are a lot of threads already regarding cold starting issues and so on. But I really hope that someone has an idea…
I´m from Germany and I drive a 2010 5.4 Raptor. Its hard here in Germany if you have a problem to go to a Ford dealer. They just standing and looking at the truck as it was a thing from another planet. So its a bit tricky here to find someone who's really able to help you with the beast.
My problem is really mysterious and it makes me freakin´out. Mostly when its colder than 5 degrees outside my truck won't start gently when he sits overnight. I turn the key and it cranks and starts with really poor idles. When I´m lucky he keeps running and comes down to normal idle in about 15-20sec.
If I´m unlucky the engine dies right after starting it. If he died I have to give him at least 4-6 tries with the foot on the pedal to get him back alive.
A big chunk of smoke is coming out of the exhaust and it smell of fuel really bad. I´m not an expert but for me it looks like if the engine is basically drowning in the morning. For some reason the injection puts way to much fuel in all 8 pots.
The mysterious thing is - that there is no failure code, no warning lamp - nothing. A friend of mine has an american shop and has a lot of skills with different american cars being a mechanic. But he has no point to start with. Everything seams alright.
We thought maybe the evap system has a failure that the valve does not shut down properly so the fuel vapors not only get soaked in the engine over night but fuel as well. all the sparks are alright, all pressures, all sensor data are alright…no real issue recognizable.
I checked my vin for possible updates or recalls - nothing.
I use different gas stations. I use 95 octane fuel.
I really don't know what to do……hope u guys can help me out.
Here is video where u can see whats going on: http://vimeo.com/84893400
