RaptorMaryland
I thought you jacked the truck up using the Frame? Only safe way?
The manual will show you a picture to not use the pumpkin but you will also notice that the manual is referencing the stock scissor jack.
That jack is not designed to lift the full rear weight of the truck, it is designed to lift just one corner. If you have a floor jack capable to handle the weight, lifting by the pumpkin is not an issue and done even by a Ford dealership if they are not using a lift. Just make sure and not put the jack pad on the lip of the diff but place it a little forward. Once up use jack stands to take the weight off the jack.
Those are nice I was going to ask about floor jacks to lift the raptor when I found this thread. I don't really like using the pumpkin but what about jacking the front ?I just picked up a pair of Sunex 10 Ton High jack stands for $199 shipped. I am finally able to get the wheels to fully droop to do maintenance on the suspension. Previously I used some 6 ton HF jackstands with some wood under them (yikes!) and that still didn't work very well.
These jackstands worked amazing and I only had to set them at level 3 to get full droop in the rear. Just wanted to share since this made my day. Now, where the hell am I going to store these things?
Thanks !
Sent from my SM-T813 using Tapatalk
Thanks but I was just wondering your jack location for picking the front of the truck since the thread was referring to the rear. I haven't tried my floor jack yet but I'm assuming it's not going to be tall enough ?Lou, based on your question, I would recommend you have a real mechanic demonstrate how to get your truck in the air. I have had trucks fall of jacks, jack stands and 2 post lifts. Stuff gets Western real quick if you know what I mean. Sometimes you get lucky though.
