WRCRaptor
You really need the GJ third brake light.
I have a GJ third brake light and the S1 reverse kit. Lots of reverse light!
The install is simple really. Takes an hour or so.It’s on my list but the install look a bit difficult
Just trying to understand, so correct me if I'm wrong, but these just tie into the wires in the rear (trailer connector?) if you only want them to come on when shifting into reverse, but you need to run a wire up to the upfitter wires in the engine bay if you want to have them come on when in reverse, PLUS be able to turn them on via an upfitter when you just want additional lighting?
Connect only to reverse circuit via tail light or trailer harness to come on in reverse.
Connect only to upfitter switch to come on when switch activated.
Connect to both reverse circuit and upfitter switch to come on automatically (no upfitter switch activation needed) when in reverse or activate upfitter switch and come on anytime.
thanks, thats what I thought. Seems like a bitch to get the wires from the rear dumper to the engine bay, but probably nice to have the option to turn them on as desired. Although could do a 3rd brake light and tie that center cargo light to the reverse circuit instead I suppose
That is an option when you get the GJ light, you can also add the reverse trigger to the center light.
